주요 콘텐츠로 건너뛰기
Fujifilm Finepix S1800 Shutter Button Replacement
필요한 것
  1. Fujifilm Finepix S1800 Shutter Button Replacement, Back Cover Assembly: 1 단계, 이미지 1/1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Shutter Button Replacement: 2 단계, 이미지 1/1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Shutter Button Replacement: 3 단계, 이미지 1/1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Shutter Button Replacement: 4 단계, 이미지 1/2 Fujifilm Finepix S1800 Shutter Button Replacement: 4 단계, 이미지 2/2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Finepix S1800 Shutter Button Replacement, LCD Screen: 5 단계, 이미지 1/2 Fujifilm Finepix S1800 Shutter Button Replacement, LCD Screen: 5 단계, 이미지 2/2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Finepix S1800 Shutter Button Replacement: 6 단계, 이미지 1/1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Finepix S1800 Shutter Button Replacement: 7 단계, 이미지 1/1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
  8. Fujifilm Finepix S1800 Shutter Button Replacement, Top Cover: 8 단계, 이미지 1/1
    • Lift the flash.
    • Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
  9. Fujifilm Finepix S1800 Shutter Button Replacement: 9 단계, 이미지 1/2 Fujifilm Finepix S1800 Shutter Button Replacement: 9 단계, 이미지 2/2
    • Remove the 4 mm screws from the left and right sides of the camera with the JIS #1 screwdriver.
  10. Fujifilm Finepix S1800 Shutter Button Replacement: 10 단계, 이미지 1/2 Fujifilm Finepix S1800 Shutter Button Replacement: 10 단계, 이미지 2/2
    • Switch the lever to disconnect the micro strip that connects the top plate.
    • Do not rip the micro strip.
  11. Fujifilm Finepix S1800 Shutter Button Replacement: 11 단계, 이미지 1/1
    • Remove the top cover.
  12. Fujifilm Finepix S1800 Shutter Button Replacement, Shutter Button: 12 단계, 이미지 1/1
    • Remove the two 2 mm screws underneath the plate with the Phillips #000 screwdriver.
  13. Fujifilm Finepix S1800 Shutter Button Replacement: 13 단계, 이미지 1/2 Fujifilm Finepix S1800 Shutter Button Replacement: 13 단계, 이미지 2/2
    • The button should fall right out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ryan Rockford
회원 가입일: 02/15/17
618 평판
안내서 5개 작성하였습니다
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G6
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
CAUTION! Different hardware versions! Following this guide might destroy your camera!
My S1800 had LCD not screwed to the body, but glued to the back cover. At the step 4 it came off together with the cover, destroying the ribbon cable, which is really short and fragile.
AntonG - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 21
전체 시간: 1,243
