주요 콘텐츠로 건너뛰기
Fujifilm Instax Mini 8 Capacitor Replacement
필요한 것
  1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: 1 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: 1 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: 1 단계, 이미지 3개 중 3개
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Capacitor Replacement: 2 단계, 이미지 2개 중 1개 Fujifilm Instax Mini 8 Capacitor Replacement: 2 단계, 이미지 2개 중 2개
    • Open the rear compartment and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Capacitor Replacement: 3 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Capacitor Replacement: 3 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Capacitor Replacement: 3 단계, 이미지 3개 중 3개
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Capacitor Replacement: 4 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Capacitor Replacement: 4 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Capacitor Replacement: 4 단계, 이미지 3개 중 3개
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  5. Fujifilm Instax Mini 8 Capacitor Replacement: 5 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Capacitor Replacement: 5 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Capacitor Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the photo-flash capacitor, then find all the connecting wires to the motherboard and battery compartment. Take notes to which exact wires they are to limit mistakes.
  6. Fujifilm Instax Mini 8 Capacitor Replacement: 6 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Capacitor Replacement: 6 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Capacitor Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully pry out the capacitor with a spudger or plastic opening tools.
  7. Fujifilm Instax Mini 8 Capacitor Replacement: 7 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Capacitor Replacement: 7 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Capacitor Replacement: 7 단계, 이미지 3개 중 3개
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bo W
회원 가입일: 10/02/12
1,010 평판
안내서 5개를 작성함
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 회원
USFT-MEIER-F15S4G1
4 회원들
안내서 26개를 작성함
3가이드 댓글
Hi There! I need a new capacitor for my daughter's Fuji Instax Mini 9. Do you supply? I am in South Africa.
Kuschi - 답글
Hi, any recommendations on where can find a shop in Kl Malaysia to fix my instax mini 8? Thanks in advance !
Miss.G - 답글
Bonjour, j'ai un instax mini 11 qui clignote orange rapidement.
Après divers manipulation de réinitialisation et de changement de pile pour des neuves rien y fait.
Est-ce que ça pourrait être un problème de condensateur qui empêche le flash de charger correctement ? Et mettrais donc l'appareil en erreur ?
Elise Tibbo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 26
지난 30일: 155
전체 시간: 27,625
