주요 콘텐츠로 건너뛰기
Fujifilm Instax Mini 8 Flash Unit Replacement
필요한 것
  1. Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: 1 단계, 이미지 2개 중 1개 Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: 1 단계, 이미지 2개 중 2개
    • You start off with the camera.
  2. Fujifilm Instax Mini 8 Flash Unit Replacement: 2 단계, 이미지 2개 중 1개 Fujifilm Instax Mini 8 Flash Unit Replacement: 2 단계, 이미지 2개 중 2개
    • Open up the back and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Flash Unit Replacement: 3 단계, 이미지 2개 중 1개 Fujifilm Instax Mini 8 Flash Unit Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two Phillips #00 screws from the bottom of the camera.
    • Remove the two screws on the side of the camera.
    • Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Flash Unit Replacement: 4 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Flash Unit Replacement: 4 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Flash Unit Replacement: 4 단계, 이미지 3개 중 3개
    • Once all screws are removed, gently pry open the front casing with your hands or a prying tool.
    • There will be a spring that attaches the front casing and the main circuit board, so take care as to not break the spring.
  5. Fujifilm Instax Mini 8 Flash Unit Replacement: 5 단계, 이미지 1개 중 1개
    • You should now be able to see the flash unit. Take care to not touch the large black capacitor on the top. It will still have a charge and will hurt.
  6. Fujifilm Instax Mini 8 Flash Unit Replacement: 6 단계, 이미지 2개 중 1개 Fujifilm Instax Mini 8 Flash Unit Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the two screws attaching the flash to the main circuit board. The flash unit will detach away from the motherboard, now leaving just the connecting wires to remove next.
  7. Fujifilm Instax Mini 8 Flash Unit Replacement: 7 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Flash Unit Replacement: 7 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Flash Unit Replacement: 7 단계, 이미지 3개 중 3개
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Boyang Wu
회원 가입일: 10/02/12
1,010 평판
안내서 5개를 작성함
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 회원
USFT-MEIER-F15S4G1
4 회원들
안내서 26개를 작성함
10가이드 댓글
Where can I purchase the flash unit?
Casey Sanders - 답글
Hi, did you ever find out where to replace the flash light unit?
Rachel Street -
Why is all the camera lights flashing red and doesn't work?
medgabby - 답글
Will the camera work without any flash, or are the connections required for the whole thing to function ?
Hyaku Gen - 답글
Where can I find the flash unit to purchase??
Maria - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 45
지난 30일: 133
전체 시간: 35,357
