주요 콘텐츠로 건너뛰기
Fujifilm Instax Mini 8 Infrared Blaster Replacement
필요한 것
  1. Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: 1 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: 1 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: 1 단계, 이미지 3개 중 3개
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Infrared Blaster Replacement: 2 단계, 이미지 2개 중 1개 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 2 단계, 이미지 2개 중 2개
    • Open the rear compartment and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Infrared Blaster Replacement: 3 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 3 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 3 단계, 이미지 3개 중 3개
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Infrared Blaster Replacement: 4 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 4 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 4 단계, 이미지 3개 중 3개
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  5. Fujifilm Instax Mini 8 Infrared Blaster Replacement: 5 단계, 이미지 3개 중 1개 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 5 단계, 이미지 3개 중 2개 Fujifilm Instax Mini 8 Infrared Blaster Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the IR blaster, remove the connecting wire ribbon by prying the connector latch open on the motherboard, then sliding it out. Once the wire ribbon is disconnected, the IR blaster can be lifted away from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bo W
회원 가입일: 10/02/12
1,010 평판
안내서 5개를 작성함
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 회원
USFT-MEIER-F15S4G1
4 회원들
안내서 26개를 작성함
2가이드 댓글
Where can I find the replacements (ir blaster)? What is the function of this part. I dropped my camera and the flash won’t turn on and films develop completely black even in broad daylight.
Jenna - 답글
Can that part be pushed back when cleaning it with a qtip? I think I pushed a bit hard but I don’t know. If it’s pushed back a bit will it effect its use?? Please help!
Orange - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 49
전체 시간: 12,335
