주요 콘텐츠로 건너뛰기
Fujifilm Instax Mini Eight Camera Shell Replacement
필요한 것
  1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 1 단계, 이미지 1/3 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 1 단계, 이미지 2/3 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 1 단계, 이미지 3/3
    • Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
    • One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
  2. Fujifilm Instax Mini Eight Camera Shell Replacement: 2 단계, 이미지 1/3 Fujifilm Instax Mini Eight Camera Shell Replacement: 2 단계, 이미지 2/3 Fujifilm Instax Mini Eight Camera Shell Replacement: 2 단계, 이미지 3/3
    • Press the tab down in order to unlatch the film compartment cover.
    • Remove the film from the compartment (if any is present)
    • Remove the compartment cover completely.
    • Begin by using the small #00 Philips head screwdriver and turning at a counter-clockwise fashion to remove screws.
  3. Fujifilm Instax Mini Eight Camera Shell Replacement: 3 단계, 이미지 1/3 Fujifilm Instax Mini Eight Camera Shell Replacement: 3 단계, 이미지 2/3 Fujifilm Instax Mini Eight Camera Shell Replacement: 3 단계, 이미지 3/3
    • Use the plastic opening tools and spudger to safely remove the front shell casing.
  4. Fujifilm Instax Mini Eight Camera Shell Replacement: 4 단계, 이미지 1/2 Fujifilm Instax Mini Eight Camera Shell Replacement: 4 단계, 이미지 2/2
    • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
    • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
    • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Boyang Wu
회원 가입일: 10/02/12
955 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 회원
USFT-MEIER-F15S4G1
4 회원들
안내서 25개 작성하였습니다
댓글 18개
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
princesslsy - 답글
but where near the exit? i cannot find it
Emily Birkler -
It's at the top of the camera where you get picture.
xxx -
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - 답글
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
Siti Syuhanna hussein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 77
30일 전: 423
전체 시간: 64,177
