주요 콘텐츠로 건너뛰기
Fujifilm Instax Minion Capacitor Replacement
필요한 것
  1. Fujifilm Instax Minion Capacitor Replacement, Camera Shell: 1 단계, 이미지 1/3 Fujifilm Instax Minion Capacitor Replacement, Camera Shell: 1 단계, 이미지 2/3 Fujifilm Instax Minion Capacitor Replacement, Camera Shell: 1 단계, 이미지 3/3
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Capacitor Replacement: 2 단계, 이미지 1/3 Fujifilm Instax Minion Capacitor Replacement: 2 단계, 이미지 2/3 Fujifilm Instax Minion Capacitor Replacement: 2 단계, 이미지 3/3
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Capacitor Replacement: 3 단계, 이미지 1/3 Fujifilm Instax Minion Capacitor Replacement: 3 단계, 이미지 2/3 Fujifilm Instax Minion Capacitor Replacement: 3 단계, 이미지 3/3
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Capacitor Replacement: 4 단계, 이미지 1/3 Fujifilm Instax Minion Capacitor Replacement: 4 단계, 이미지 2/3 Fujifilm Instax Minion Capacitor Replacement: 4 단계, 이미지 3/3
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Capacitor Replacement: 5 단계, 이미지 1/3 Fujifilm Instax Minion Capacitor Replacement: 5 단계, 이미지 2/3 Fujifilm Instax Minion Capacitor Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Capacitor Replacement: 6 단계, 이미지 1/3 Fujifilm Instax Minion Capacitor Replacement: 6 단계, 이미지 2/3 Fujifilm Instax Minion Capacitor Replacement: 6 단계, 이미지 3/3
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Capacitor Replacement, Capacitor: 7 단계, 이미지 1/3 Fujifilm Instax Minion Capacitor Replacement, Capacitor: 7 단계, 이미지 2/3 Fujifilm Instax Minion Capacitor Replacement, Capacitor: 7 단계, 이미지 3/3
    • Remove the four 4.5 mm screws inside the battery holder with a long #00 Phillips screwdriver.
  8. Fujifilm Instax Minion Capacitor Replacement: 8 단계, 이미지 1/3 Fujifilm Instax Minion Capacitor Replacement: 8 단계, 이미지 2/3 Fujifilm Instax Minion Capacitor Replacement: 8 단계, 이미지 3/3
    • Gently pull on the battery holder to remove it from the case, exposing the capacitor.
    • Pull up on the backside of the capacitor to remove it from the battery holder.
    • The capacitor will have a small amount of adhesive holding it onto the battery holder. Keep this intact, but don't worry if it is damaged.
    • Be careful not to touch the wire leads on the front of the capacitor, as you could get shocked.
  9. Fujifilm Instax Minion Capacitor Replacement: 9 단계, 이미지 1/2 Fujifilm Instax Minion Capacitor Replacement: 9 단계, 이미지 2/2
    • Desolder the ends of the wires from the leads of the capacitor to remove it.
    • Take note of the connections between the wires and leads for reassembly. The brown wire connects to side with white line and the white wire connects to the other side.
    • Be careful not to touch both leads of the capacitor with your soldering iron. This will bridge the connection and could create a spark.
결론
Jeffery
회원 가입일: 03/28/15
220 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G6, Livingston Spring 2018 Cal Poly, Team S18-G6, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G6
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 12
전체 시간: 647
