주요 콘텐츠로 건너뛰기
Fujifilm Instax Minion Flash Bulb Replacement
필요한 것
  1. Fujifilm Instax Minion Flash Bulb Replacement, Camera Shell: 1 단계, 이미지 1/3 Fujifilm Instax Minion Flash Bulb Replacement, Camera Shell: 1 단계, 이미지 2/3 Fujifilm Instax Minion Flash Bulb Replacement, Camera Shell: 1 단계, 이미지 3/3
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Flash Bulb Replacement: 2 단계, 이미지 1/3 Fujifilm Instax Minion Flash Bulb Replacement: 2 단계, 이미지 2/3 Fujifilm Instax Minion Flash Bulb Replacement: 2 단계, 이미지 3/3
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Flash Bulb Replacement: 3 단계, 이미지 1/3 Fujifilm Instax Minion Flash Bulb Replacement: 3 단계, 이미지 2/3 Fujifilm Instax Minion Flash Bulb Replacement: 3 단계, 이미지 3/3
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Flash Bulb Replacement: 4 단계, 이미지 1/3 Fujifilm Instax Minion Flash Bulb Replacement: 4 단계, 이미지 2/3 Fujifilm Instax Minion Flash Bulb Replacement: 4 단계, 이미지 3/3
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Flash Bulb Replacement: 5 단계, 이미지 1/3 Fujifilm Instax Minion Flash Bulb Replacement: 5 단계, 이미지 2/3 Fujifilm Instax Minion Flash Bulb Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Flash Bulb Replacement: 6 단계, 이미지 1/3 Fujifilm Instax Minion Flash Bulb Replacement: 6 단계, 이미지 2/3 Fujifilm Instax Minion Flash Bulb Replacement: 6 단계, 이미지 3/3
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Flash Bulb Replacement, Flash Bulb: 7 단계, 이미지 1/2 Fujifilm Instax Minion Flash Bulb Replacement, Flash Bulb: 7 단계, 이미지 2/2
    • Once the shell is off, remove the one 6.5 mm screw that is attached to the flash bulb using a Phillips #00 screwdriver.
  8. Fujifilm Instax Minion Flash Bulb Replacement: 8 단계, 이미지 1/3 Fujifilm Instax Minion Flash Bulb Replacement: 8 단계, 이미지 2/3 Fujifilm Instax Minion Flash Bulb Replacement: 8 단계, 이미지 3/3
    • Remove the flash bulb from the circuit board by shifting it towards the side with the motor and lifting.
  9. Fujifilm Instax Minion Flash Bulb Replacement: 9 단계, 이미지 1/2 Fujifilm Instax Minion Flash Bulb Replacement: 9 단계, 이미지 2/2
    • Place the bulb over an open surface and use the soldering gun to melt the three connections off the bulb.
    • During reassembly, use the picture to attach the correct wire to the correct connection on the bulb (white-right, gray-top, brown-left).
  10. Fujifilm Instax Minion Flash Bulb Replacement: 10 단계, 이미지 1/1
    • The flash bulb should now be detached completely from the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonnah Lee
회원 가입일: 04/18/18
473 평판
안내서 3개 작성하였습니다
Cal Poly, Team S18-G6, Livingston Spring 2018 Cal Poly, Team S18-G6, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G6
4 회원들
안내서 11개 작성하였습니다
댓글 3개
Hi, does anyone know how to find replacement bulb?
Ci Chali (Cichali) - 답글
same question here!
Socorro Ruiz - 답글
Hi, I did bulb replacement on Mini 40 with the help of this guide. I found similar looking bulb on Aliexpress. I suggest you to look online for a replacement xenon tube lamp that is similar in look and length. I found lamp for Nikon models ******D40 D40X D60 D60X D3000 fitting and working fine with Instax Mini 40
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 47
전체 시간: 2,619
