주요 콘텐츠로 건너뛰기
Fujifilm Instax Minion Lens Bellow Replacement
필요한 것
  1. Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: 1 단계, 이미지 1/3 Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: 1 단계, 이미지 2/3 Fujifilm Instax Minion Lens Bellow Replacement, Camera Shell: 1 단계, 이미지 3/3
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Lens Bellow Replacement: 2 단계, 이미지 1/3 Fujifilm Instax Minion Lens Bellow Replacement: 2 단계, 이미지 2/3 Fujifilm Instax Minion Lens Bellow Replacement: 2 단계, 이미지 3/3
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Lens Bellow Replacement: 3 단계, 이미지 1/3 Fujifilm Instax Minion Lens Bellow Replacement: 3 단계, 이미지 2/3 Fujifilm Instax Minion Lens Bellow Replacement: 3 단계, 이미지 3/3
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Lens Bellow Replacement: 4 단계, 이미지 1/3 Fujifilm Instax Minion Lens Bellow Replacement: 4 단계, 이미지 2/3 Fujifilm Instax Minion Lens Bellow Replacement: 4 단계, 이미지 3/3
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Lens Bellow Replacement: 5 단계, 이미지 1/3 Fujifilm Instax Minion Lens Bellow Replacement: 5 단계, 이미지 2/3 Fujifilm Instax Minion Lens Bellow Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Lens Bellow Replacement: 6 단계, 이미지 1/3 Fujifilm Instax Minion Lens Bellow Replacement: 6 단계, 이미지 2/3 Fujifilm Instax Minion Lens Bellow Replacement: 6 단계, 이미지 3/3
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Lens Bellow Replacement, Lens Bellow: 7 단계, 이미지 1/2 Fujifilm Instax Minion Lens Bellow Replacement, Lens Bellow: 7 단계, 이미지 2/2
    • Once the shell is off, remove the two 4.5 mm screws from the circuit board using a Phillips #00 screwdriver.
  8. Fujifilm Instax Minion Lens Bellow Replacement: 8 단계, 이미지 1/1
    • Once the circuit board is off and to the side, remove the four 4.5 mm screws that are around the front lens case using a Phillips #00 screwdriver.
  9. Fujifilm Instax Minion Lens Bellow Replacement: 9 단계, 이미지 1/2 Fujifilm Instax Minion Lens Bellow Replacement: 9 단계, 이미지 2/2
    • Turn the camera onto its back and remove the four 4.5 mm screws attaching the lens bellow to the case using a Phillips #00 screwdriver.
    • The lens must be extended in order to have access to the screws.
    • Remove the rectangular screw casing from the back of the camera.
  10. Fujifilm Instax Minion Lens Bellow Replacement: 10 단계, 이미지 1/3 Fujifilm Instax Minion Lens Bellow Replacement: 10 단계, 이미지 2/3 Fujifilm Instax Minion Lens Bellow Replacement: 10 단계, 이미지 3/3
    • Flip the camera over to its front side again and remove the lens casing by lifting it up and off the camera.
    • Finally, remove the lens bellow by lifting it up and off the camera.
결론
Jonnah Lee
회원 가입일: 04/18/18
473 평판
안내서 3개 작성하였습니다
Cal Poly, Team S18-G6, Livingston Spring 2018 Cal Poly, Team S18-G6, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G6
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 527
