주요 콘텐츠로 건너뛰기
Fujifilm Instax Minion Motor Replacement
필요한 것
  1. Fujifilm Instax Minion Motor Replacement, Camera Shell: 1 단계, 이미지 1/3 Fujifilm Instax Minion Motor Replacement, Camera Shell: 1 단계, 이미지 2/3 Fujifilm Instax Minion Motor Replacement, Camera Shell: 1 단계, 이미지 3/3
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Motor Replacement: 2 단계, 이미지 1/3 Fujifilm Instax Minion Motor Replacement: 2 단계, 이미지 2/3 Fujifilm Instax Minion Motor Replacement: 2 단계, 이미지 3/3
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Motor Replacement: 3 단계, 이미지 1/3 Fujifilm Instax Minion Motor Replacement: 3 단계, 이미지 2/3 Fujifilm Instax Minion Motor Replacement: 3 단계, 이미지 3/3
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Motor Replacement: 4 단계, 이미지 1/3 Fujifilm Instax Minion Motor Replacement: 4 단계, 이미지 2/3 Fujifilm Instax Minion Motor Replacement: 4 단계, 이미지 3/3
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Motor Replacement: 5 단계, 이미지 1/3 Fujifilm Instax Minion Motor Replacement: 5 단계, 이미지 2/3 Fujifilm Instax Minion Motor Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Motor Replacement: 6 단계, 이미지 1/3 Fujifilm Instax Minion Motor Replacement: 6 단계, 이미지 2/3 Fujifilm Instax Minion Motor Replacement: 6 단계, 이미지 3/3
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Motor Replacement, Motor: 7 단계, 이미지 1/2 Fujifilm Instax Minion Motor Replacement, Motor: 7 단계, 이미지 2/2
    • Remove the four 4.5 mm #00 Phillips screws on the battery compartment.
  8. Fujifilm Instax Minion Motor Replacement: 8 단계, 이미지 1/1
    • Lift up the battery compartment to free up the motor.
  9. Fujifilm Instax Minion Motor Replacement: 9 단계, 이미지 1/1
    • Unscrew the two 2.9mm Phillips #00 screws holding the motor to the frame.
  10. Fujifilm Instax Minion Motor Replacement: 10 단계, 이미지 1/2 Fujifilm Instax Minion Motor Replacement: 10 단계, 이미지 2/2
    • Remove the motor from the frame.
  11. Fujifilm Instax Minion Motor Replacement: 11 단계, 이미지 1/2 Fujifilm Instax Minion Motor Replacement: 11 단계, 이미지 2/2
    • Desolder the wires from the leads of the capacitor.
    • Take note of the connections between the wires and leads for reassembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeffery
회원 가입일: 03/28/15
220 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G6, Livingston Spring 2018 Cal Poly, Team S18-G6, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G6
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
Can anyone help finding a motor for the instax 8 or 9? I can't find one to fit any help appreciated
Jordan Kelly - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 24
전체 시간: 1,356
