주요 콘텐츠로 건너뛰기
소개
Use this guide to replace a damaged back case, or open the case to access other components of your camera.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
부품
지정된 부품이 없습니다.
  1. Fujifilm X-M1 Back Case Replacement, Battery: step 1, image 1 of 2 Fujifilm X-M1 Back Case Replacement, Battery: step 1, image 2 of 2
    • Turn the camera upside down to locate the battery compartment.
    • Slide the button up to open the compartment.
    • Slide the orange button up to release the battery.
    • The battery is not shown in these photos.
  2. Fujifilm X-M1 Back Case Replacement, Back Case: step 2, image 1 of 1
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  3. Fujifilm X-M1 Back Case Replacement: step 3, image 1 of 1
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  4. Fujifilm X-M1 Back Case Replacement: step 4, image 1 of 1
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  5. Fujifilm X-M1 Back Case Replacement: step 5, image 1 of 2 Fujifilm X-M1 Back Case Replacement: step 5, image 2 of 2
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  6. Fujifilm X-M1 Back Case Replacement: step 6, image 1 of 3 Fujifilm X-M1 Back Case Replacement: step 6, image 2 of 3 Fujifilm X-M1 Back Case Replacement: step 6, image 3 of 3
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  7. Fujifilm X-M1 Back Case Replacement: step 7, image 1 of 1
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  8. Fujifilm X-M1 Back Case Replacement: step 8, image 1 of 2 Fujifilm X-M1 Back Case Replacement: step 8, image 2 of 2
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  9. Fujifilm X-M1 Back Case Replacement: step 9, image 1 of 3 Fujifilm X-M1 Back Case Replacement: step 9, image 2 of 3 Fujifilm X-M1 Back Case Replacement: step 9, image 3 of 3
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  10. Fujifilm X-M1 Back Case Replacement: step 10, image 1 of 1
    • Slide the frame around the LCD to remove it from the camera.
  11. Fujifilm X-M1 Back Case Replacement: step 11, image 1 of 1
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  12. Fujifilm X-M1 Back Case Replacement: step 12, image 1 of 2 Fujifilm X-M1 Back Case Replacement: step 12, image 2 of 2
    • Use tweezers to unhook the speaker near the left handgrip.
  13. Fujifilm X-M1 Back Case Replacement: step 13, image 1 of 2 Fujifilm X-M1 Back Case Replacement: step 13, image 2 of 2
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  14. Fujifilm X-M1 Back Case Replacement: step 14, image 1 of 3 Fujifilm X-M1 Back Case Replacement: step 14, image 2 of 3 Fujifilm X-M1 Back Case Replacement: step 14, image 3 of 3
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
    • Remove the back case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kelsea Weber
회원 가입일: 2015년 11월 12일
18,607 평판
안내서 32개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 15,124개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 20
전체 시간: 1,129
