주요 콘텐츠로 건너뛰기
Fujifilm XP20 Battery Replacement
  1. Fujifilm XP20 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Fujifilm XP20 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Fujifilm XP20 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • To begin, open the the battery hatch on the right side of the camera, relative to the LCD screen. The battery hatch is the larger of the two. To open, simply slide the black button in the direction of the arrow next to it and the hatch will pop open.
  2. Fujifilm XP20 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Now that the hatch is open, you should be able to see the battery. To take out the old battery, just push down on it and then it will slightly eject itself, making it possible for you to grab with your finger tips.
    • At this point, this battery cannot be used again, be sure to dispose of it in a proper manner.
결론
작성자
2다른 기여자 명과 함께
Craig Swartz
회원 가입일: 10/08/16
106 평판
안내서 1개를 작성함
IUPUI, Team 1-1, Wilson Fall 2016 IUPUI, Team 1-1, Wilson Fall 2016 회원
IUPUI-WILSON-F16S1G1
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 37
전체 시간: 1,580
