주요 콘텐츠로 건너뛰기
Fujifilm XP20 Rear Case Replacement
필요한 것
  1. Fujifilm XP20 Rear Case Replacement, Rear Case: 1 단계, 이미지 1/3 Fujifilm XP20 Rear Case Replacement, Rear Case: 1 단계, 이미지 2/3 Fujifilm XP20 Rear Case Replacement, Rear Case: 1 단계, 이미지 3/3
    • Using a 1.5mm Hex Screwdriver, remove the two 3.0 mm hex screws on the front of the camera.
    • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws on the bottom of the front face.
  2. Fujifilm XP20 Rear Case Replacement: 2 단계, 이미지 1/3 Fujifilm XP20 Rear Case Replacement: 2 단계, 이미지 2/3 Fujifilm XP20 Rear Case Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screws on the bottom of the camera closer to the back.
    • Using a Phillips #00 screwdriver remove the two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. Fujifilm XP20 Rear Case Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. Fujifilm XP20 Rear Case Replacement: 4 단계, 이미지 1/3 Fujifilm XP20 Rear Case Replacement: 4 단계, 이미지 2/3 Fujifilm XP20 Rear Case Replacement: 4 단계, 이미지 3/3
    • Using a 1.5mm Hex screwdriver, remove the 3.0 mm hex screw on top edge of silver panel.
    • Using a Phillips #00 screwdriver, remove the 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. Fujifilm XP20 Rear Case Replacement: 5 단계, 이미지 1/3 Fujifilm XP20 Rear Case Replacement: 5 단계, 이미지 2/3 Fujifilm XP20 Rear Case Replacement: 5 단계, 이미지 3/3
    • Unlatch the four clasps located on each side of the camera by hand.
    • The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm XP20 Battery Replacement for instructions.
  6. Fujifilm XP20 Rear Case Replacement: 6 단계, 이미지 1/3 Fujifilm XP20 Rear Case Replacement: 6 단계, 이미지 2/3 Fujifilm XP20 Rear Case Replacement: 6 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove the seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
결론
Stephen Harden
회원 가입일: 10/08/16
243 평판
안내서 2개 작성하였습니다
IUPUI, Team 1-1, Wilson Fall 2016 IUPUI, Team 1-1, Wilson Fall 2016 회원
IUPUI-WILSON-F16S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 624
