주요 콘텐츠로 건너뛰기
Fujitisu LifeBook U810 Battery Replacement
  1. Fujitisu LifeBook U810 Battery Replacement, Battery: 1 단계, 이미지 1/3 Fujitisu LifeBook U810 Battery Replacement, Battery: 1 단계, 이미지 2/3 Fujitisu LifeBook U810 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the Lifebook so it's underside is showing and you see a small latch with the lock symbol on the right side.
  2. Fujitisu LifeBook U810 Battery Replacement: 2 단계, 이미지 1/1
    • Push the latch to the right to release the battery.
  3. Fujitisu LifeBook U810 Battery Replacement: 3 단계, 이미지 1/3 Fujitisu LifeBook U810 Battery Replacement: 3 단계, 이미지 2/3 Fujitisu LifeBook U810 Battery Replacement: 3 단계, 이미지 3/3
    • Hold the latch in the unlocked position and with your other hand pull the battery straight out from the back of the device.
결론
Emmy Hughes
회원 가입일: 10/22/18
147 평판
안내서 1개 작성함
UC Davis, Team S4-G7, Lore Fall 2018 UC Davis, Team S4-G7, Lore Fall 2018 회원
UCD-LORE-F18S4G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 447
