이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Push the tab down as far as possible using your finger or plastic opening tool to unlock the disc drive.
While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
Unscrew two 2.4mm screws at the bottom using a Phillips #0.
Also unscrew another 2.4mm screw in the same line as the first two, located at the disc drive's opening and closest to the bottom right corner.
다른 3명이 해당 안내서를 완성하였습니다.
