소개
Following these steps, you can effectively replace your display.
부품
지정된 부품이 없습니다.
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Remove the following screws, all labeled "3."
Two 8.63mm screws.
One 7.65mm screw.
One 5.74mm screw.
Remove the following screw, labeled "15."
One 17.81mm screw.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
