주요 콘텐츠로 건너뛰기
Fujitsu LifeBook N3510 Hinge Cover Replacement
필요한 것
  1. Fujitsu LifeBook N3510 Hinge Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Hinge Cover Replacement: 2 단계, 이미지 1/1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: 3 단계, 이미지 1/3 Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: 3 단계, 이미지 2/3 Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: 3 단계, 이미지 3/3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Hinge Cover Replacement: 4 단계, 이미지 1/1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Hinge Cover Replacement: 5 단계, 이미지 1/3 Fujitsu LifeBook N3510 Hinge Cover Replacement: 5 단계, 이미지 2/3 Fujitsu LifeBook N3510 Hinge Cover Replacement: 5 단계, 이미지 3/3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Hinge Cover Replacement: 6 단계, 이미지 1/2 Fujitsu LifeBook N3510 Hinge Cover Replacement: 6 단계, 이미지 2/2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Hinge Cover Replacement: 7 단계, 이미지 1/2 Fujitsu LifeBook N3510 Hinge Cover Replacement: 7 단계, 이미지 2/2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
결론
Neil Daniels
회원 가입일: 01/17/11
1,411 평판
안내서 11개 작성하였습니다
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G18
3 회원들
안내서 22개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 3,370
