주요 콘텐츠로 건너뛰기
Fujitsu LifeBook N3510 Optical Drive Replacement
필요한 것
  1. Fujitsu LifeBook N3510 Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Optical Drive Replacement, Hinge Cover: 3 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement, Hinge Cover: 3 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Optical Drive Replacement, Hinge Cover: 3 단계, 이미지 3개 중 3개
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Optical Drive Replacement: 5 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 5 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Optical Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Optical Drive Replacement: 6 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 6 단계, 이미지 2개 중 2개
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Optical Drive Replacement: 7 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Optical Drive Replacement, Keyboard: 8 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement, Keyboard: 8 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Optical Drive Replacement, Keyboard: 8 단계, 이미지 3개 중 3개
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Optical Drive Replacement: 9 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Optical Drive Replacement: 10 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 10 단계, 이미지 2개 중 2개
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Optical Drive Replacement, Metal Motherboard Cover: 11 단계, 이미지 1개 중 1개
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Optical Drive Replacement: 12 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 12 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Optical Drive Replacement: 12 단계, 이미지 3개 중 3개
    • Lift the cover with fingers and remove.
  13. Fujitsu LifeBook N3510 Optical Drive Replacement, Display: 13 단계, 이미지 1개 중 1개
    • Remove labeled screws.
  14. Fujitsu LifeBook N3510 Optical Drive Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the screws from the bottom of the hinge as shown in the image.
  15. Fujitsu LifeBook N3510 Optical Drive Replacement: 15 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 15 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Optical Drive Replacement: 15 단계, 이미지 3개 중 3개
    • Use a spudger to detach and remove cables from the motherboard.
  16. Fujitsu LifeBook N3510 Optical Drive Replacement: 16 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 16 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Optical Drive Replacement: 16 단계, 이미지 3개 중 3개
    • Unplug highlighted cables from the wireless module.
  17. Fujitsu LifeBook N3510 Optical Drive Replacement: 17 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 17 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Optical Drive Replacement: 17 단계, 이미지 3개 중 3개
    • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
  18. Fujitsu LifeBook N3510 Optical Drive Replacement, Top Palm Rest Cover: 18 단계, 이미지 1개 중 1개
    • Remove the 4 labeled screws.
  19. Fujitsu LifeBook N3510 Optical Drive Replacement: 19 단계, 이미지 1개 중 1개
    • Remove screws from bottom of laptop as shown in the picture.
  20. Fujitsu LifeBook N3510 Optical Drive Replacement: 20 단계, 이미지 1개 중 1개
    • Lift the palm rest cover from the base of the laptop.
    • You may use spudger if needed, lift from the front corners as shown.
  21. Fujitsu LifeBook N3510 Optical Drive Replacement: 21 단계, 이미지 1개 중 1개
    • Great job! You have successfully removed the old palm rest cover.
  22. Fujitsu LifeBook N3510 Optical Drive Replacement, Optical Drive: 22 단계, 이미지 1개 중 1개
    • Remove the single screw labeled "5".
  23. Fujitsu LifeBook N3510 Optical Drive Replacement: 23 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Optical Drive Replacement: 23 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Optical Drive Replacement: 23 단계, 이미지 3개 중 3개
    • Remove optical drive.
결론
작성자
6다른 기여자 명과 함께
Neil Daniels
회원 가입일: 01/17/11
1,411 평판
안내서 11개를 작성함
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G18
3 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 1,763
