주요 콘텐츠로 건너뛰기
Fujitsu LifeBook U810 Wireless LAN card Replacement
필요한 것
  1. Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: 1 단계, 이미지 3개 중 1개 Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: 1 단계, 이미지 3개 중 2개 Fujitsu LifeBook U810 Wireless LAN card Replacement, Wireless LAN card: 1 단계, 이미지 3개 중 3개
    • Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
  2. Fujitsu LifeBook U810 Wireless LAN card Replacement: 2 단계, 이미지 3개 중 1개 Fujitsu LifeBook U810 Wireless LAN card Replacement: 2 단계, 이미지 3개 중 2개 Fujitsu LifeBook U810 Wireless LAN card Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 5mm screws with a Phillips #0 screwdriver.
    • Remove the wireless LAN card from the device.
  3. Fujitsu LifeBook U810 Wireless LAN card Replacement: 3 단계, 이미지 2개 중 1개 Fujitsu LifeBook U810 Wireless LAN card Replacement: 3 단계, 이미지 2개 중 2개
    • Detach the two antenna cables connected to the wireless LAN card by gently pulling them out of place.
결론
작성자
4다른 기여자 명과 함께
Anne Kutt
회원 가입일: 10/22/18
197 평판
안내서 1개를 작성함
UC Davis, Team S4-G7, Lore Fall 2018 UC Davis, Team S4-G7, Lore Fall 2018 회원
UCD-LORE-F18S4G7
3 회원들
안내서 4개를 작성함
댓글 2개
Is there a BIOS whitelist for this machine? I wanted to replace my wifi card due to OS incompatibility but I've seen conflicting reports.
Adam Birnbaum - 답글
No whitelist. Any card that physically fits seems to work.
Adam Birnbaum -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 727
