주요 콘텐츠로 건너뛰기
Fujitsu Lifebook E556 HDD/SSD Replacement
필요한 것
  1. Fujitsu Lifebook E556 HDD/SSD Replacement, Removing Battery: 1 단계, 이미지 1개 중 1개
    • Remove battery:
    • 1. Pull down and hold that little tab.
    • 2. Move left that slider.
    • 3. Pull up to remove battery from laptop.
  2. Fujitsu Lifebook E556 HDD/SSD Replacement, Removing HDD/SSD Cover: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • To remove HDD/SSD cover, you need to:
    • 1. Remove screw holding cover.
    • 2. Pull up the cover by notch visible right next to screw hole. If difficult to pull by finger, use a plastic card or guitar pick.
  3. Fujitsu Lifebook E556 HDD/SSD Replacement, Removing HDD/SSD: 3 단계, 이미지 1개 중 1개
    • To remove HDD/SSD, you need to pull disk outwards of connector.
    • When disconnected, pull up the disk away from bay.
    • Important! If you wanna place a new disk, make sure it is SLIM format. It is standard for 2,5" SSDs, so nothing to worry about.
    • 2,5" HDDs were made in 2 different thicknesses: standard (9mm) and slim (7mm)
    • Mine laptop is lacking two rubber bands, that are holding disk. They're not a necessity, cover has some thick rubber on it too, so disk should stay in place.
결론
작성자
3다른 기여자 명과 함께
Michał Kurda
회원 가입일: 02/17/22
920 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 729
