주요 콘텐츠로 건너뛰기
Fujitsu Lifebook E556 Keyboard Replacement
필요한 것
  1. Fujitsu Lifebook E556 Keyboard Replacement, Removing Battery: 1 단계, 이미지 1개 중 1개
    • Remove battery:
    • 1. Pull down and hold that little tab.
    • 2. Move left that slider.
    • 3. Pull up to remove battery from laptop.
  2. Fujitsu Lifebook E556 Keyboard Replacement, Removing Screws: 2 단계, 이미지 2개 중 1개 Fujitsu Lifebook E556 Keyboard Replacement, Removing Screws: 2 단계, 이미지 2개 중 2개
    • Remove screws marked in white and red circles.
    • Note: those in red circles are holding the keyboard and are different than those in white circles. Don't mix them!
  3. Fujitsu Lifebook E556 Keyboard Replacement, Removing plastic bar: 3 단계, 이미지 2개 중 1개 Fujitsu Lifebook E556 Keyboard Replacement, Removing plastic bar: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Put a plastic tool (plastic card, spudger or guitar pick) between that bar and the rest of case (in places marked by arrows). It's holding only on clips- gentle pry until it breaks free.
    • When either of sides are free, pry that tab from behind (area marked by red rectangle, but from the back of the laptop - image very difficult to take).
  4. Fujitsu Lifebook E556 Keyboard Replacement, Removing Keyboard: 4 단계, 이미지 2개 중 1개 Fujitsu Lifebook E556 Keyboard Replacement, Removing Keyboard: 4 단계, 이미지 2개 중 2개
    • Now, keyboard can be lifted, but it still connected to the motherboard. Gently pull it up.
    • When in horizontal position, you will see keyboard connector on the left. Pull the tabs out (1) then pull the flex cable out too (2).
    • Keyboard is now free.
결론
작성자
1다른 기여자 명과 함께
Michał Kurda
회원 가입일: 02/17/22
866 평판
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 28
지난 30일: 91
전체 시간: 1,230
