주요 콘텐츠로 건너뛰기
Fujitsu Lifebook S6120 Fan Replacement
필요한 것
  1. Fujitsu Lifebook S6120 Fan Replacement, Battery: 1 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement, Battery: 1 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: 2 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Fan Replacement: 4 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 4 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Fan Replacement: 5 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 5 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement: 5 단계, 이미지 3개 중 3개
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Fan Replacement, Keyboard: 6 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: 6 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: 6 단계, 이미지 3개 중 3개
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Fan Replacement: 7 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 7 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: 8 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: 8 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: 8 단계, 이미지 3개 중 3개
    • Push the secure clips outward.
    • The Adapter should pop up.
  9. Fujitsu Lifebook S6120 Fan Replacement: 9 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 9 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove the wires from the Adapter.
  10. Fujitsu Lifebook S6120 Fan Replacement: 10 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Take out the Adapter and carefully pull the wires out from the metal casing.
  11. Fujitsu Lifebook S6120 Fan Replacement, Motherboard: 11 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement, Motherboard: 11 단계, 이미지 2개 중 2개
    • Use a Philips head #0 to remove the 5mm screws.
    • Use a Philips head #00 to remove the 4mm screws.
  12. Fujitsu Lifebook S6120 Fan Replacement: 12 단계, 이미지 1개 중 1개
    • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
  13. Fujitsu Lifebook S6120 Fan Replacement: 13 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the ribbon from the motherboard with a pair of tweezers.
  14. Fujitsu Lifebook S6120 Fan Replacement: 14 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 14 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement: 14 단계, 이미지 3개 중 3개
    • Use a 5mm nut driver to unscrew the nuts.
  15. Fujitsu Lifebook S6120 Fan Replacement: 15 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 15 단계, 이미지 2개 중 2개
    • Pull the ribbon tab up and off the motherboard.
  16. Fujitsu Lifebook S6120 Fan Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the metal plate covering the motherboard.
  17. Fujitsu Lifebook S6120 Fan Replacement: 17 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the 3.5mm screws with a Philips head #0.
    • Remove the metal bracket and other pieces that rely on it for structure.
  18. Fujitsu Lifebook S6120 Fan Replacement: 18 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 18 단계, 이미지 2개 중 2개
    • Pinch your fingers around the base of the connector and pull it out.
  19. Fujitsu Lifebook S6120 Fan Replacement: 19 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 19 단계, 이미지 2개 중 2개
    • Lift the motherboard off the plastic base.
  20. Fujitsu Lifebook S6120 Fan Replacement, Fan: 20 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement, Fan: 20 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement, Fan: 20 단계, 이미지 3개 중 3개
    • Using a Philips head size #0 remove the 3mm screw on the back of the motherboard.
  21. Fujitsu Lifebook S6120 Fan Replacement: 21 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 21 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Fan Replacement: 21 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers detach the cable from the motherboard.
  22. Fujitsu Lifebook S6120 Fan Replacement: 22 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Fan Replacement: 22 단계, 이미지 2개 중 2개
    • The fan can now be removed from the motherboard.
결론
작성자
3다른 기여자 명과 함께
Jessi Gallant
회원 가입일: 03/19/18
899 평판
안내서 7개를 작성함
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G5
3 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 731
