주요 콘텐츠로 건너뛰기
Fujitsu Lifebook S6120 Keyboard Replacement
필요한 것
  1. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: 2 단계, 이미지 2개 중 1개 Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 3개
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Fujitsu Lifebook S6120 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Fujitsu Lifebook S6120 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jessi Gallant
회원 가입일: 03/19/18
899 평판
안내서 7개를 작성함
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G5
3 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 22
전체 시간: 1,236
