주요 콘텐츠로 건너뛰기
Fujitsu Lifebook S6120 RAM Replacement
필요한 것
  1. Fujitsu Lifebook S6120 RAM Replacement, Battery: 1 단계, 이미지 1/3 Fujitsu Lifebook S6120 RAM Replacement, Battery: 1 단계, 이미지 2/3 Fujitsu Lifebook S6120 RAM Replacement, Battery: 1 단계, 이미지 3/3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 RAM Replacement, RAM: 2 단계, 이미지 1/2 Fujitsu Lifebook S6120 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Use a Philips head #0 to remove the 4mm screws to the RAM cover.
  3. Fujitsu Lifebook S6120 RAM Replacement: 3 단계, 이미지 1/3 Fujitsu Lifebook S6120 RAM Replacement: 3 단계, 이미지 2/3 Fujitsu Lifebook S6120 RAM Replacement: 3 단계, 이미지 3/3
    • Use the plastic opening tool to lift the RAM cover.
    • Use your hands to slide the cover off.
  4. Fujitsu Lifebook S6120 RAM Replacement: 4 단계, 이미지 1/3 Fujitsu Lifebook S6120 RAM Replacement: 4 단계, 이미지 2/3 Fujitsu Lifebook S6120 RAM Replacement: 4 단계, 이미지 3/3
    • Remove RAM module by pushing security clips outward.
    • The RAM module should pop out.
    • Carefully pull RAM module out of the computer.
결론
Jessi Gallant
회원 가입일: 03/19/18
899 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G5
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 391
