주요 콘텐츠로 건너뛰기
Fujitsu Lifebook Stylistic Q584 Battery Replacement
필요한 것
  1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Back Case: 1 단계, 이미지 1개 중 1개
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Inner Back Shield: 4 단계, 이미지 1개 중 1개
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: 6 단계, 이미지 1개 중 1개
  7. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Battery: 8 단계, 이미지 1개 중 1개
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: 9 단계, 이미지 1개 중 1개
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: 10 단계, 이미지 1개 중 1개
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the battery from the casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Connor Stanton
회원 가입일: 09/21/17
613 평판
안내서 6개를 작성함
Washington State, Team S1-G3, Phelps-Hillen Fall 2017 Washington State, Team S1-G3, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S1G3
5 회원들
안내서 10개를 작성함
1가이드 댓글
I have flickering video problems after a drop, its probably video cable loose. Where is the video cable, To try reseating.
Vince - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 24
전체 시간: 3,527
