주요 콘텐츠로 건너뛰기
Fujitsu Lifebook Stylistic Q584 Camera Replacement
필요한 것
  1. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Back Case: 1 단계, 이미지 1/1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Camera Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Camera Replacement: 3 단계, 이미지 1/1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Inner Back Shield: 4 단계, 이미지 1/1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Camera Replacement: 5 단계, 이미지 1/1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Camera Replacement: 6 단계, 이미지 1/1
  7. Fujitsu Lifebook Stylistic Q584 Camera Replacement: 7 단계, 이미지 1/1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: 8 단계, 이미지 1/2 Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: 8 단계, 이미지 2/2
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Camera Replacement: 9 단계, 이미지 1/2 Fujitsu Lifebook Stylistic Q584 Camera Replacement: 9 단계, 이미지 2/2
    • Pull the ribbon straight up from the back of the camera board
  10. Fujitsu Lifebook Stylistic Q584 Camera Replacement: 10 단계, 이미지 1/1
    • Remove the single 2mm screw using a PH000 screwdriver from the camera board.
결론
Connor Stanton
회원 가입일: 09/21/17
613 평판
안내서 6개 작성하였습니다
Washington State, Team S1-G3, Phelps-Hillen Fall 2017 Washington State, Team S1-G3, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 287
