주요 콘텐츠로 건너뛰기
Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement
필요한 것
  1. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Back Case: 1 단계, 이미지 1/1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Inner Back Shield: 4 단계, 이미지 1/1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 6 단계, 이미지 1/1
  7. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 7 단계, 이미지 1/1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Battery: 8 단계, 이미지 1/1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 9 단계, 이미지 1/1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 10 단계, 이미지 1/1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 11 단계, 이미지 1/1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Headphone Jack: 12 단계, 이미지 1/1
    • Remove the two 0.2 mm screws with a PH00 Screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 13 단계, 이미지 1/1
    • Remove the two 0.2 mm screws with a PH00 screwdriver
  14. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 14 단계, 이미지 1/1
    • Now use an ESD-safe spudger to gently pry up the silver piece and flip it over. Be sure not to remove this piece completely!
  15. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 15 단계, 이미지 1/2 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 15 단계, 이미지 2/2
    • Use an ESD-safe spudger to gently push the yellow piece out from the white cradle.
  16. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 16 단계, 이미지 1/2 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: 16 단계, 이미지 2/2
    • When removing the headphone jack, simply use your fingers to pull out the white and black piece altogether.
결론
Briana Cockerham
회원 가입일: 03/26/19
130 평판
안내서 1개 작성함
IUPUI, Team S1-G1, Henning Spring 2019 IUPUI, Team S1-G1, Henning Spring 2019 회원
IUPUI-HENNING-S19S1G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 440
