주요 콘텐츠로 건너뛰기
Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement
필요한 것
  1. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement, Back Case: 1 단계, 이미지 1/1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: 3 단계, 이미지 1/1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement, Inner Back Shield: 4 단계, 이미지 1/1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: 5 단계, 이미지 1/1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: 6 단계, 이미지 1/1
  7. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: 7 단계, 이미지 1/1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
결론
Spencer Bacon
회원 가입일: 09/21/17
410 평판
안내서 4개 작성하였습니다
Washington State, Team S1-G3, Phelps-Hillen Fall 2017 Washington State, Team S1-G3, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S1G3
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 13
전체 시간: 473
