주요 콘텐츠로 건너뛰기
Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement
필요한 것
  1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Back Case: 1 단계, 이미지 1개 중 1개
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Inner Back Shield: 4 단계, 이미지 1개 중 1개
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 6 단계, 이미지 1개 중 1개
  7. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Battery: 8 단계, 이미지 1개 중 1개
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 9 단계, 이미지 1개 중 1개
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 10 단계, 이미지 1개 중 1개
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Motherboard: 12 단계, 이미지 1개 중 1개
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 13 단계, 이미지 1개 중 1개
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 14 단계, 이미지 1개 중 1개
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 15 단계, 이미지 1개 중 1개
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 16 단계, 이미지 3개 중 1개 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 16 단계, 이미지 3개 중 2개 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the connector with an ESD-safe spudger.
  18. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, MicroSD Card: 18 단계, 이미지 1개 중 1개
    • After removing the motherboard, use an ESD-safe spudger to pry up the MicroSD card from the slot.
    • Gently separate the MicroSD card from the device.
결론
작성자
3다른 기여자 명과 함께
Casey
회원 가입일: 03/25/19
283 평판
안내서 2개를 작성함
IUPUI, Team S1-G1, Henning Spring 2019 IUPUI, Team S1-G1, Henning Spring 2019 회원
IUPUI-HENNING-S19S1G1
3 회원들
안내서 3개를 작성함
1가이드 댓글
I have some OS problem can the SSD be replaced..?
Faiz Rahmathulla - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 641
