주요 콘텐츠로 건너뛰기
Fujitsu Siemens Amilo Pro Keyboard Replacement
필요한 것
  1. Fujitsu Siemens Amilo Pro Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Fujitsu Siemens Amilo Pro Keyboard Replacement: 2 단계, 이미지 1/1
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. Fujitsu Siemens Amilo Pro Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the one screw holding in the keyboard.
  4. Fujitsu Siemens Amilo Pro Keyboard Replacement: 4 단계, 이미지 1/1
    • Pull the keyboard up towards you.
  5. Fujitsu Siemens Amilo Pro Keyboard Replacement: 5 단계, 이미지 1/1
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremy Scalpello
회원 가입일: 04/25/10
282 평판
안내서 1개 작성함
댓글 한 개
try to focus the image while taking the picture so people can understand better were to touch
storm builder - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 12
전체 시간: 15,534
