주요 콘텐츠로 건너뛰기
소개
A repair manual for the Fujitsu Siemens Amilo Pro 2010 and 2020 and 2030 which shows you how to replace the keyboard!
  1. Remove AC adapter and battery.
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Use a flat head screwdriver to pry out the hinge cover.
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  4. Remove the one screw holding in the keyboard.
    • Remove the one screw holding in the keyboard.
  5. Pull the keyboard up towards you.
    • Pull the keyboard up towards you.
  6. Pull the ribbon cable and the keyboard will come out.
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremy Scalpello
회원 가입일: 2010년 04월 25일
298 평판
안내서 1개 작성함
try to focus the image while taking the picture so people can understand better were to touch
storm builder - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 32
전체 시간: 14,435
