주요 콘텐츠로 건너뛰기
Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement
필요한 것
  1. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement, CMOS Battery: 1 단계, 이미지 1/1
    • Turn the laptop upside down and prepare the tools needed and the battery.
  2. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: 2 단계, 이미지 1/1
    • Remove the 4 philips screws that secure the back cover.
  3. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: 3 단계, 이미지 1/1
    • With the cover removed, we can see the battery.
  4. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: 4 단계, 이미지 1/1
    • Turn the laptop around so you can see and access the battery. Release the battery with the flat screwdriver (1), then gently push it upward (2). Be careful not to let it slip into the laptop case or you will have to disassemble it completely.
  5. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: 5 단계, 이미지 1/2 Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: 5 단계, 이미지 2/2
    • If you have a multimeter, check the old battery. A good one should read 3 V or higher. A fresh one reads 3.2 V or more.
    • In this case, the old was really bad, at only 2.7 V.
    • The replacement one is good, 3.22 V.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Nicola Nascimento
회원 가입일: 11/28/15
372 평판
안내서 1개 작성함
댓글 한 개
nice... do you have information about the location of the cmos battery in the Fujitsu LH 532 model? rosez.v@hotmail.com
Victor Rosez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 27
전체 시간: 13,659
