주요 콘텐츠로 건너뛰기
Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement
필요한 것
  1. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn the laptop over so that the bottom of the laptop faces you.
  2. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 2 단계, 이미지 1/2 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Locate the hard drive cover and remove the screw.
  3. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 3 단계, 이미지 1/2 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Now you can use your finger to pull the cover off.
  4. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 4 단계, 이미지 1/3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 4 단계, 이미지 2/3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Pull on the pull tab to release the hard drive.
    • Now you can take the hard drive out of the laptop.
  5. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 5 단계, 이미지 1/3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 5 단계, 이미지 2/3 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: 5 단계, 이미지 3/3
    • There is a screw on each corner of the hard drive bracket. To take the hard drive out of its bracket you need to remove the 4 screws.
    • Do not take the screws out of the hard drive itself, only from the bracket.
    • With the screws removed the drive slides out of the bracket.
    • Now you can replace the hard drive with a new one.
결론
다른 5명이 해당 안내서를 완성하였습니다.
storm
회원 가입일: 07/07/12
552 평판
안내서 2개 작성하였습니다
댓글 2개
Please I need a password protection my computer is locked I need a code to unlock my computer pls Esprimo mobile V5515 please help me
sadik G Ibrahim - 답글
Is it a Windows password or a BIOS password?
storm -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 21
전체 시간: 5,963
