주요 콘텐츠로 건너뛰기
Fujtsu Lifebook Model A6110 Disk Drive Replacement
필요한 것
  1. Fujtsu Lifebook Model A6110 Disk Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 2 단계, 이미지 1개 중 1개
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
  3. Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 1개 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 2개 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 3개
    • The disk drive will be located on the side of the computer, on the top-left corner
    • Using a Phillips #1 screwdriver, remove the two 6 mm screws which are located above the disk drive. Remove the screws by turning your screwdriver counter-clockwise.
  4. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 4 단계, 이미지 2개 중 1개 Fujtsu Lifebook Model A6110 Disk Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the metal spudger in the gap between the disk drive and the laptop's body itself, as seen in the picture.
    • Push the spudger down, so that it is behind the drive.
    • Gently pull the disk drive out from the laptop until it unlatches.
  5. Fujtsu Lifebook Model A6110 Disk Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Once the disk-drive has been unlatched from its slot, pull it gently from the laptop case.
결론
작성자
3다른 기여자 명과 함께
Cody Moniz
회원 가입일: 10/19/16
416 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 UMass Dartmouth, Team 3-2, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G2
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 18
전체 시간: 487
