주요 콘텐츠로 건너뛰기
Full Solar Cooker Assembly
필요한 것
  1. Full Solar Cooker Assembly, Parabolic Solar Cooker Part Inventory: 1 단계, 이미지 1/1
    • An inventory for all parabolic solar cooker parts follows below.
    • 6 Reflective Dish Sections
    • 1 Expansion Pipe
    • 1 Tripod Center Plate
    • 1 T-Bar
    • 3 Tripod Base Legs
    • 1 Cooker Flat
    • 1 Pipe Ring
  2. Full Solar Cooker Assembly: 2 단계, 이미지 1/1
    • The solar cooker part inventory continues below.
    • 1 Cooker Flat Stand
    • 2 Cotter Pins
    • 36 x 10mm Nut/Bolt Pairs
    • 6 Pipe Ring Brackets
    • 12 x 14mm Nut/Bolt Pairs
    • 2 Cooker Assembly Adjustment Star Knobs
  3. Full Solar Cooker Assembly, Assembling Parabolic Solar Cooker Tripod Base Stand: 3 단계, 이미지 1/2 Full Solar Cooker Assembly, Assembling Parabolic Solar Cooker Tripod Base Stand: 3 단계, 이미지 2/2
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  4. Full Solar Cooker Assembly: 4 단계, 이미지 1/1
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
  5. Full Solar Cooker Assembly, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: 5 단계, 이미지 1/2 Full Solar Cooker Assembly, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: 5 단계, 이미지 2/2
    • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
    • It does not matter which direction the 14mm bolt is inserted from.
  6. Full Solar Cooker Assembly, Assembling Reflective Parabolic Dish: 6 단계, 이미지 1/2 Full Solar Cooker Assembly, Assembling Reflective Parabolic Dish: 6 단계, 이미지 2/2
    • Before you begin, be sure you have all parts and tools needed for assembly and a construction area that is at least two meters in diameter.
    • Lay two triangular sections side-by-side with pointed edges and bases adjacent to each other.
    • Since the sections are not flat, it is advisable to prop one end up on a box or similar object to give more stability during assembly.
  7. Full Solar Cooker Assembly: 7 단계, 이미지 1/1
    • Use the 10 mm nuts and bolts to attach the two plates together. First, hand thread each bolt/nut pair, then use two 10 mm wrenches secure them.
    • DO NOT install a nut and bolt in the THIRD hole from the center (pointed end of the section). This is where the Pipe Ring Bracket is attached later on.
  8. Full Solar Cooker Assembly: 8 단계, 이미지 1/3 Full Solar Cooker Assembly: 8 단계, 이미지 2/3 Full Solar Cooker Assembly: 8 단계, 이미지 3/3
    • After firmly fastening the two sections together, return to the third hole which was left empty. In addition to a nut and bolt, you will also need a pipe ring bracket.
    • Install the 10mm nut/bolt again but with the bolt passing through the single holed side of the bracket. Hand thread and use 10mm wrenches to tighten.
    • Be sure the bracket is NOT installed between the edges of the dish sections.
    • The direction the bracket faces does not matter.
  9. Full Solar Cooker Assembly: 9 단계, 이미지 1/2 Full Solar Cooker Assembly: 9 단계, 이미지 2/2
    • Repeat steps 2-3 until you have assembled the entire reflective dish, complete with all six sections.
    • Remember to install the pipe ring brackets in the correct place all the way around the reflective dish in the third hole from the center.
  10. Full Solar Cooker Assembly, Full Solar Cooker Assembly: 10 단계, 이미지 1/1
    • Place the assembled solar panel dish face down with the metal brackets on the top and facing up.
    • Set the pipe ring in the metal brackets circling the center of the dish.
  11. Full Solar Cooker Assembly: 11 단계, 이미지 1/2 Full Solar Cooker Assembly: 11 단계, 이미지 2/2
    • Insert a 14mm bolt through each six metal brackets and secure with a nut.
    • Tighten using two 14mm wrenches until secure.
  12. Full Solar Cooker Assembly: 12 단계, 이미지 1/3 Full Solar Cooker Assembly: 12 단계, 이미지 2/3 Full Solar Cooker Assembly: 12 단계, 이미지 3/3
    • Slide the cross bearer into the two holes in the support ring making sure the top of the cross sticks through the center of the solar panel dish.
    • Insert a 14mm bolt into the metal bracket on the support ring through the adjustable arm and secure with a nut.
    • Tighten with your hands.
  13. Full Solar Cooker Assembly: 13 단계, 이미지 1/2 Full Solar Cooker Assembly: 13 단계, 이미지 2/2
    • Insert a cotter pin through the holes at each end of the cross bearer.
  14. Full Solar Cooker Assembly: 14 단계, 이미지 1/3 Full Solar Cooker Assembly: 14 단계, 이미지 2/3 Full Solar Cooker Assembly: 14 단계, 이미지 3/3
    • Attach the top of the center plate of the tripod base stand to the cross bearer bar making sure the flat side of the tripod legs points away from the solar panel dish.
  15. Full Solar Cooker Assembly: 15 단계, 이미지 1/1
    • Stand the solar cooker upright on the tripod stand and attach the cooker ring stand to the cross bar coming through the center of the solar panel dish.
    • Screw a star knob screw into the hole in the top of the cross bar and tighten with your hand.
결론
To disassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Ashlie Reott
회원 가입일: 10/20/13
340 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-30, Amido Fall 2013 Cal Poly, Team 4-30, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G30
4 회원들
안내서 6개 작성하였습니다
댓글 3개
Thank you for these instructions. If it wasn't for these instructions, I would not have been able to put the solar cooker (as seen in the photograghs) together. The seller's manual fail to use photographs as this illustration clarifies.
Chris - 답글
Thank you very much ,mine came without the instructions so this has been so helpful
crafty mav - 답글
Hi everyone, I want to ask about the material used over the dish. whether it's concave mirror or some sheet. kindly someone clear my confusion. Thank you
Zoobia Abbasi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 2,390
