주요 콘텐츠로 건너뛰기
Furbo Dog Camera Speaker and Microphone Assembly Replacement
필요한 것
  1. Furbo Dog Camera  Speaker and Microphone Assembly Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 2 단계, 이미지 3개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 2 단계, 이미지 3개 중 2개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 3 단계, 이미지 3개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 3 단계, 이미지 3개 중 2개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 4 단계, 이미지 3개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 4 단계, 이미지 3개 중 2개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
  5. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 5 단계, 이미지 2개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
  6. Furbo Dog Camera  Speaker and Microphone Assembly Replacement, Camera Lens: 6 단계, 이미지 3개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement, Camera Lens: 6 단계, 이미지 3개 중 2개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement, Camera Lens: 6 단계, 이미지 3개 중 3개
    • Carefully remove the copper foiling that surrounds the camera hardware.
  7. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 7 단계, 이미지 2개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the 2.5 mm screws at the top of the camera hardware.
  8. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 8 단계, 이미지 2개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pry the metal backing off of the camera hardware.
  9. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 9 단계, 이미지 2개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the 0.4 mm screws that attach the camera to the Furbo case.
  10. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 10 단계, 이미지 3개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 10 단계, 이미지 3개 중 2개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 10 단계, 이미지 3개 중 3개
    • Gently pry the camera off and detach it from the Furbo.
  11. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 11 단계, 이미지 3개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 11 단계, 이미지 3개 중 2개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 11 단계, 이미지 3개 중 3개
    • Detach the wire attaching the camera hardware from the Furbo.
  12. Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 12 단계, 이미지 2개 중 1개 Furbo Dog Camera  Speaker and Microphone Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Once removed, you may replace your camera.
  13. Furbo Dog Camera  Speaker and Microphone Assembly Replacement, Speaker and Microphone Assembly: 13 단계, 이미지 1개 중 1개
    • The part indicated in red is the microphone and speaker
    • Remove the microphone and speaker component and replace with new part
결론
작성자
1다른 기여자 명과 함께
Sarah Teague
회원 가입일: 03/21/22
265 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 17
전체 시간: 467
