주요 콘텐츠로 건너뛰기
Fusion5 5.5 Gen II Midframe Replacement
필요한 것
  1. Fusion5 5.5 Gen II Midframe Replacement, Back Cover: 1 단계, 이미지 1/2 Fusion5 5.5 Gen II Midframe Replacement, Back Cover: 1 단계, 이미지 2/2
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Midframe Replacement, Midframe: 2 단계, 이미지 1/2 Fusion5 5.5 Gen II Midframe Replacement, Midframe: 2 단계, 이미지 2/2
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Midframe Replacement: 3 단계, 이미지 1/2 Fusion5 5.5 Gen II Midframe Replacement: 3 단계, 이미지 2/2
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
결론
Hwajin
회원 가입일: 09/16/19
560 평판
안내서 5개 작성하였습니다
댓글 한 개
Hi Hwajin,
Thanks for your guides to the Fusion5. Do you happen to have a full User Manual. The quick start guide is useless.
Regards,
Richard
richardsailor1936@gmail.com - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 252
