주요 콘텐츠로 건너뛰기
G&G CM RK47 Airsoft Disassembly
필요한 것
  1. G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: 1 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: 1 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: 1 단계, 이미지 3/3
    • Start by pressing the top cover retainer button and lifting the top cover off of the gun.
  2. G&G CM RK47 Airsoft Disassembly: 2 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 2 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 2 단계, 이미지 3/3
    • Pull the thin black rod away from the top cover button and swing it outwards.
    • Remove the small screw from the plastic receiver cover using a #0 Phillips screwdriver.
  3. G&G CM RK47 Airsoft Disassembly: 3 단계, 이미지 1/2 G&G CM RK47 Airsoft Disassembly: 3 단계, 이미지 2/2
    • Lift the plastic receiver cover from the receiver and remove it.
    • Slide the top cover retainer button out of its groove and remove it.
  4. G&G CM RK47 Airsoft Disassembly: 4 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 4 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 4 단계, 이미지 3/3
    • Remove the four screws on the underside of the receiver with a 2mm hex driver.
    • Pull the barrel assembly out of the receiver.
    • Remove the two screws holding the hop-up unit in place.
    • Pull the inner barrel out of the outer barrel.
  5. G&G CM RK47 Airsoft Disassembly: 5 단계, 이미지 1/2 G&G CM RK47 Airsoft Disassembly: 5 단계, 이미지 2/2
    • Remove the screw a the bottom of the pistol grip with a #2 Phillips screwdriver.
    • Remove the two motor mount screws with a 2mm hex driver.
  6. G&G CM RK47 Airsoft Disassembly: 6 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 6 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 6 단계, 이미지 3/3
    • Using a flat head screwdriver, pry off the selector lever cap.
    • Once the cap is removed, remove the screw underneath with a #2 Phillips screwdriver.
    • Remove the selector lever.
  7. G&G CM RK47 Airsoft Disassembly: 7 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 7 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 7 단계, 이미지 3/3
    • Carefully remove the gearbox from the receiver, making sure that the wires don't get stuck.
  8. G&G CM RK47 Airsoft Disassembly: 8 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 8 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 8 단계, 이미지 3/3
    • Using a 2.5mm hex driver, remove the three screws that hold the stock to the receiver.
    • Pull the stock away from the receiver to remove it.
  9. G&G CM RK47 Airsoft Disassembly: 9 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 9 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 9 단계, 이미지 3/3
    • Remove the safety from the right side of the gearbox.
    • Remove the selector gear screw with a 2mm hex driver as shown.
    • Remove the selector gear assembly.
  10. G&G CM RK47 Airsoft Disassembly: 10 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 10 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 10 단계, 이미지 3/3
    • Lift the tabs on the small black cap behind the trigger, and then remove the cap.
    • Pull the wires out from under the tabs on the spring plate that runs along the top of the gearbox.
    • Carefully remove the spring plate by tapping it gently with a plastic hammer until it slides off the front of the gearbox.
  11. G&G CM RK47 Airsoft Disassembly: 11 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 11 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 11 단계, 이미지 3/3
    • Remove the four remaining gearbox screws with a 2mm hex driver.
    • Hold down the cylinder with your thumb while prying the gearbox apart from the top.
    • As you remove the right half of the gearbox, be sure to hold down the cylinder, piston, and spring assembly so that they do not pop out under tension.
    • Also keep a close eye out for any gear shims that may dislodge themselves as you are taking the gearbox apart.
  12. G&G CM RK47 Airsoft Disassembly: 12 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 12 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 12 단계, 이미지 3/3
    • Slowly lift the spring guide out of the gearbox along with the piston spring.
    • Remove the entire piston and cylinder assembly with the tappet plate, tappet plate spring, and air nozzle.
    • Remove the trigger assembly and lift up the wire harness, unhooking the trigger plunger spring in the process.
  13. G&G CM RK47 Airsoft Disassembly: 13 단계, 이미지 1/3 G&G CM RK47 Airsoft Disassembly: 13 단계, 이미지 2/3 G&G CM RK47 Airsoft Disassembly: 13 단계, 이미지 3/3
    • Pull the trigger plunger out of the wire harness.
    • Remove the three gears and the anti-reversal latch. Be careful not to misplace any of the shims or bushings, or the anti-reversal latch spring.
  14. G&G CM RK47 Airsoft Disassembly: 14 단계, 이미지 1/1
    • The RK47 is now fully disassembled.
결론
다른 4명이 해당 안내서를 완성하였습니다.
101 Tech USA
회원 가입일: 08/06/12
4,127 평판
안내서 17개 작성하였습니다
댓글 한 개
That is really cool, and where can you buy this!
Ultimate Gamer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 20
전체 시간: 7,101
