주요 콘텐츠로 건너뛰기
G'z One Boulder Front Ear Speaker Replacement
필요한 것
  1. G'z One Boulder Front Ear Speaker Replacement, Inside Screen Cover: 1 단계, 이미지 1개 중 1개
    • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
    • Make note that two of the screws closest to the hinge are longer than the other two.
  2. G'z One Boulder Front Ear Speaker Replacement: 2 단계, 이미지 2개 중 1개 G'z One Boulder Front Ear Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two side screws.
    • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
  3. G'z One Boulder Front Ear Speaker Replacement: 3 단계, 이미지 2개 중 1개 G'z One Boulder Front Ear Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the screen cover from the rest of the lid.
  4. G'z One Boulder Front Ear Speaker Replacement: 4 단계, 이미지 2개 중 1개 G'z One Boulder Front Ear Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Your phone should look like the picture to the left.
    • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
  5. G'z One Boulder Front Ear Speaker Replacement, Front Logic Board: 5 단계, 이미지 3개 중 1개 G'z One Boulder Front Ear Speaker Replacement, Front Logic Board: 5 단계, 이미지 3개 중 2개 G'z One Boulder Front Ear Speaker Replacement, Front Logic Board: 5 단계, 이미지 3개 중 3개
    • Remove one screw located on the left side of the phone with the pictured orientation in mind.
    • This will release the logic board from the back case.
    • Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
  6. G'z One Boulder Front Ear Speaker Replacement: 6 단계, 이미지 3개 중 1개 G'z One Boulder Front Ear Speaker Replacement: 6 단계, 이미지 3개 중 2개 G'z One Boulder Front Ear Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
    • The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
    • Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
  7. G'z One Boulder Front Ear Speaker Replacement, Front Ear Speaker: 7 단계, 이미지 2개 중 1개 G'z One Boulder Front Ear Speaker Replacement, Front Ear Speaker: 7 단계, 이미지 2개 중 2개
    • Lift speaker towards yourself out of the white plastic container.
    • Gently unplug the ribbon by pulling it to the left with the pictured orientation in mind.
    • Be careful when unplugging connector as the ribbon connecting piece is extremely fragile.'
결론
작성자
3다른 기여자 명과 함께
Raymond Caulder
회원 가입일: 03/11/13
22 평판
안내서 3개를 작성함
Clemson, Team 13-3, Benson Spring 2013 Clemson, Team 13-3, Benson Spring 2013 회원
CLEM-BENSON-S13S13G3
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 452
