소개
Although the blow-back AK's are very similar to the other AK lines there are some slight differences to watch out for.
Before disassemble dry fire the AEG twice on semi auto and then remove the battery.
First step of disassemble is to remove the dust cover by pressing in the button at back of the gun.
Now lift off the dust cover from the back.
To remove the hop-up and inner barrel remove the screws shown.
With hop-up and inner barrel out you can separate the hop-up from the barrel. First slide the hop-up to it's lowest setting. Now removing the plastic clip piece.
Slide off the hop-up to expose a green rubber seal piece called the bucking.
Remove the plastic piece behind the trigger. You should be able to pry it off with your fingernails or in extreme cases a Flathead screw driver.
If you did not fire the gun in semi auto before disassemble or the piston didn't reset properly you can use a tool with a hook or needle nose pliers to release the anti-reversal latch shown hear.
Now remove the screws shown
Start cracking open the gearbox starting from the back end. Wile doing so hold down the piston cylinder and spring to prevent part from flying around.
Once the top half of the shell is off quickly remove the spring guide and spring so you no longer risk pieces flying out.
If you wish to remove the gears remember not to loose any the of the shims (little washer looking things) unless you already know how to shim.
Hear is a guide for G&G AEG Shimming Guide Airsoft
If you have no reason for removing the trigger it is easiest to leave it in place. It can be tricky sometimes to get into place. However if you need remove it it can just simple be poled out.
