주요 콘텐츠로 건너뛰기
G'z One Boulder New Antenna Replacement
필요한 것
  1. G'z One Boulder New Antenna Replacement, New Battery: 1 단계, 이미지 2개 중 1개 G'z One Boulder New Antenna Replacement, New Battery: 1 단계, 이미지 2개 중 2개
    • Turn locking device on back side of phone marked by the rectangle counter clockwise.
  2. G'z One Boulder New Antenna Replacement: 2 단계, 이미지 1개 중 1개
    • Remove battery by grabbing the sides and pulling upward.
    • If battery was malfunctioning due to age or corrosion, there may be battery acid residue on the battery and the back of the phone. Wear gloves in order to prevent skin irritation.
  3. G'z One Boulder New Antenna Replacement, New Antenna: 3 단계, 이미지 3개 중 1개 G'z One Boulder New Antenna Replacement, New Antenna: 3 단계, 이미지 3개 중 2개 G'z One Boulder New Antenna Replacement, New Antenna: 3 단계, 이미지 3개 중 3개
    • Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws.
    • Once all screws are removed the case will easily lift off.
  4. G'z One Boulder New Antenna Replacement: 4 단계, 이미지 2개 중 1개 G'z One Boulder New Antenna Replacement: 4 단계, 이미지 2개 중 2개
    • With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
  5. G'z One Boulder New Antenna Replacement: 5 단계, 이미지 2개 중 1개 G'z One Boulder New Antenna Replacement: 5 단계, 이미지 2개 중 2개
    • With screw removed, gently pull the antenna outward. It should slide out easily.
결론
작성자
5다른 기여자 명과 함께
troy
회원 가입일: 03/11/13
1 평판
안내서 2개를 작성함
Clemson, Team 13-3, Benson Spring 2013 Clemson, Team 13-3, Benson Spring 2013 회원
CLEM-BENSON-S13S13G3
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 568
