주요 콘텐츠로 건너뛰기
G603 Wheel Encoder Replacement
필요한 것
  1. G603 Wheel Encoder Replacement, Remove Top Cover & Batteries: 1 단계, 이미지 1/1
    • Remove magnetic top cover, batteries, and wireless receiver (if currently stored inside the mouse)
  2. G603 Wheel Encoder Replacement, Remove Mouse Feet: 2 단계, 이미지 1/3 G603 Wheel Encoder Replacement, Remove Mouse Feet: 2 단계, 이미지 2/3 G603 Wheel Encoder Replacement, Remove Mouse Feet: 2 단계, 이미지 3/3
    • Carefully remove the feet to reveal the 4 screws holding the top and bottom shells together
    • NOTE: These feet can be removed carefully enough to be reused. Only the top and bottom feet need to be removed, not the one around the sensor
  3. G603 Wheel Encoder Replacement, Remove the four Phillips #00 Screws: 3 단계, 이미지 1/1
    • Use Phillips #00 to remove the four bottom screws
  4. G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 4 단계, 이미지 1/3 G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 4 단계, 이미지 2/3 G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 4 단계, 이미지 3/3
    • Start at the top above the left and right click and slowly work your way around the shells until they are separated
    • Be careful not to damage the power connector or ribbon cable going from the top shell's boards/battery to the bottom shell's board
  5. G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 5 단계, 이미지 1/3 G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 5 단계, 이미지 2/3 G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 5 단계, 이미지 3/3
    • Start with the red and black power cable and gently pull it out
    • Once power cable is removed, you should be able to unfold the two halves and unplug the white ribbon cable
  6. G603 Wheel Encoder Replacement, Remove Encoder Ribbon Cable: 6 단계, 이미지 1/1
    • Gently pull out the black ribbon cable connecting the encoder board to the main board
  7. G603 Wheel Encoder Replacement, Remove 5 Phillips #00 Screws: 7 단계, 이미지 1/1
    • Remove the Phillips #00 screws holding the encoder board in place
  8. G603 Wheel Encoder Replacement, Remove Encoder Board & Wheel: 8 단계, 이미지 1/1
    • Remove the encoder board from the bottom shell
    • Gently remove the wheel from the older encoder board
    • NOTE: The old wheel can be reused in the replacement encoder board
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jim
회원 가입일: 06/17/23
331 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 54
30일 전: 220
전체 시간: 1,412
