주요 콘텐츠로 건너뛰기
GARDENA Smart Gateway Repair
필요한 것
  1. GARDENA Smart Gateway Repair, Open device: 1 단계, 이미지 2개 중 1개 GARDENA Smart Gateway Repair, Open device: 1 단계, 이미지 2개 중 2개
    • Remove the rubber feet. Below are four Torx T9 screws.
  2. GARDENA Smart Gateway Repair, Fuse: 2 단계, 이미지 1개 중 1개
    • Identify if the fuse is blown. Take a multimeter and measure the resistance. There should be no measurable resistance.
    • If the fuse is defective it should be replaced with a new one. Component listed under parts.
  3. GARDENA Smart Gateway Repair, TVS Diode: 3 단계, 이미지 1개 중 1개
    • Second component likely to fail is the TVS Diode (Transient-voltage-suppression diode). It is used to protect the sensitive circuit from overvoltage.
    • Measure the resistance on the two terminals. Resistance should be infinite.
    • If component is broken the circuit is shorted. Therefore the component can be removed in order to repair the device. Afterwards the circuit is not protected against overvoltage anymore!
  4. GARDENA Smart Gateway Repair, Test the device: 4 단계, 이미지 1개 중 1개
    • Power LED should light up green
결론
작성자
1다른 기여자 명과 함께
Computerix
회원 가입일: 05/24/23
820 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 1,265
