주요 콘텐츠로 건너뛰기
GATEWAY ML6720 Battery Replacement
필요한 것
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Battery Replacement: 2 단계, 이미지 1/1
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Battery Replacement: 3 단계, 이미지 1/2 GATEWAY ML6720 Battery Replacement: 3 단계, 이미지 2/2
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Battery Replacement: 4 단계, 이미지 1/2 GATEWAY ML6720 Battery Replacement: 4 단계, 이미지 2/2
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Battery Replacement: 5 단계, 이미지 1/2 GATEWAY ML6720 Battery Replacement: 5 단계, 이미지 2/2
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
결론
Nathan Da Silva
회원 가입일: 10/19/16
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G3
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 293
