주요 콘텐츠로 건너뛰기
GATEWAY ML6720 Hard Drive Replacement
필요한 것
  1. GATEWAY ML6720 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Flip the laptop on to its backside.
  2. GATEWAY ML6720 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Locate the hard drive at the bottom left corner of the laptop's backside.
  3. GATEWAY ML6720 Hard Drive Replacement: 3 단계, 이미지 1/2 GATEWAY ML6720 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Insert the correct screwdriver mentioned in this guide.
    • Fully loosen and remove each of the two screws located at the top left and bottom left corners of the hard drive's cover plate.
  4. GATEWAY ML6720 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Slide the hard drive's cover plate out to the left and take it off.
  5. GATEWAY ML6720 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Pop the hard drive out of the compartment.
결론
Nathan Da Silva
회원 가입일: 10/19/16
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G3
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 341
