주요 콘텐츠로 건너뛰기
GATEWAY ML6720 Keyboard Replacement
필요한 것
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
  5. GATEWAY ML6720 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 1개 GATEWAY ML6720 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 2개 GATEWAY ML6720 Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 3개
    • Be careful of losing the screws because of how small they are
    • Remove the six 2.0mm Phillips screws and panels from the back of the RAM, motherboard, and laptop fan.
  6. GATEWAY ML6720 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Have your laptop remained on the backside
    • Remove the twelve identical 2.0mm Phillips Screws located around the back of the laptop using the Phillips #0 Screwdriver.
    • Remove the entire back panel of the laptop
  7. GATEWAY ML6720 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 GATEWAY ML6720 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using a pair of tweezers or the tip of your screw driver, dig into the laptop cover and apply force to pop it out.
    • Do this on the left and right side of the cover.
  8. GATEWAY ML6720 Keyboard Replacement: 9 단계, 이미지 2개 중 1개 GATEWAY ML6720 Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Pull up the keyboard with your finger.
결론
작성자
8다른 기여자 명과 함께
Nathan Da Silva
회원 가입일: 10/19/16
416 평판
안내서 4개를 작성함
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G3
2 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 4
전체 시간: 683
