소개
If the motor of your laminator is not working, it may need to be replaced. Since the motor is inside of the device, you need to disassemble the Laminator. For this guide, you will need to open the top of the device using a Phillips #2 screwdriver to remove the screws. It is not difficult to open the laminator, but some of the components may be difficult to pull apart.
부품
부품은 필요하지 않습니다.
  1. Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device. Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device.
    • Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device.
  2. Open the top of the device, and the inside of the Laminator will be exposed as shown.
    • Open the top of the device, and the inside of the Laminator will be exposed as shown.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Using the Phillips #2 screwdriver, remove two 9 mm long screws on the side of the main component that keep the motor in place. Using the Phillips #2 screwdriver, remove two 9 mm long screws on the side of the main component that keep the motor in place.
    • Using the Phillips #2 screwdriver, remove two 9 mm long screws on the side of the main component that keep the motor in place.
  5. Using the Phillips #2 screwdriver, remove three 8.5 mm long screws and washers on the front edge of the plastic casing. Using the Phillips #2 screwdriver, remove three 8.5 mm long screws and washers on the front edge of the plastic casing.
    • Using the Phillips #2 screwdriver, remove three 8.5 mm long screws and washers on the front edge of the plastic casing.
  6. Lift the motor out of the plastic casing.
    • Lift the motor out of the plastic casing.
결론
Yujia Tang
회원 가입일: 2018년 07월 11일
300 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G1, Wilson Summer 2018 IUPUI, Team S1-G1, Wilson Summer 2018 회원
IUPUI-WILSON-SU18S1G1
5 회원들
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 69
