주요 콘텐츠로 건너뛰기
GD Midea FT30-3D Fan Base Disassembly
필요한 것
  1. GD Midea FT30-3D Fan Base Disassembly, Bottom Base: 1 단계, 이미지 1개 중 1개
    • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
  2. GD Midea FT30-3D Fan Base Disassembly: 2 단계, 이미지 2개 중 1개 GD Midea FT30-3D Fan Base Disassembly: 2 단계, 이미지 2개 중 2개
    • Locate the gray base support release tabs found on either side pictured in the first image.
    • There are release tabs on each side of the base.
    • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
  3. GD Midea FT30-3D Fan Base Disassembly: 3 단계, 이미지 1개 중 1개
    • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
    • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
  4. GD Midea FT30-3D Fan Base Disassembly: 4 단계, 이미지 1개 중 1개
    • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
  5. GD Midea FT30-3D Fan Base Disassembly: 5 단계, 이미지 1개 중 1개
    • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
    • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
  6. GD Midea FT30-3D Fan Base Disassembly: 6 단계, 이미지 1개 중 1개
    • Once all five screws have been removed the base cover should fall right off with out any effort.
    • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alan Su
회원 가입일: 10/03/12
840 평판
안내서 6개를 작성함
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 회원
CPSU-REGAN-F12S24G28
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 1,772
