주요 콘텐츠로 건너뛰기
GD Midea FT30-3D Fan Blades Replacement
필요한 것
  1. GD Midea FT30-3D Fan Blades Replacement, Fan Blades: 1 단계, 이미지 1/2 GD Midea FT30-3D Fan Blades Replacement, Fan Blades: 1 단계, 이미지 2/2
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  2. GD Midea FT30-3D Fan Blades Replacement: 2 단계, 이미지 1/1
    • Pull the front fan guard off.
  3. GD Midea FT30-3D Fan Blades Replacement: 3 단계, 이미지 1/2 GD Midea FT30-3D Fan Blades Replacement: 3 단계, 이미지 2/2
    • Remove the spinner from the center of the fan blade.
    So how do i take the spinner off the fan
    Martha Meza - 답글
    H how do I take the spinner off the center of a fan I don't know how
    Martha Meza - 답글
  4. GD Midea FT30-3D Fan Blades Replacement: 4 단계, 이미지 1/1
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Alan Su
회원 가입일: 10/03/12
810 평판
안내서 6개 작성하였습니다
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 회원
CPSU-REGAN-F12S24G28
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Where do you buy the fan blades?
charlie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 33
전체 시간: 3,245
