주요 콘텐츠로 건너뛰기
소개
This guide will show you how to replace the oscillation mechanism.
부품
지정된 부품이 없습니다.
  1. Release the 3 clips that attach the front fan guard to the rear fan guard. Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  2. Pull the front fan guard off.
    • Pull the front fan guard off.
  3. Remove the spinner from the center of the fan blade. Remove the spinner from the center of the fan blade.
    • Remove the spinner from the center of the fan blade.
  4. The fan blades should now be easy to lift up.
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
  5. Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
    • Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
    • The plastic nut needs to be twisted off; like a screw.
  6. Remove the screw at the center of the oscillator knob and remove the oscillator knob. If the oscillator knob is clean and undamaged then the problem is with the oscillator. If the knob is damaged replace it and test your fan before proceeding forward in the guide.
    • Remove the screw at the center of the oscillator knob and remove the oscillator knob.
    • If the oscillator knob is clean and undamaged then the problem is with the oscillator. If the knob is damaged replace it and test your fan before proceeding forward in the guide.
  7. Remove the front motor housing by removing 4 screws.
    • Remove the front motor housing by removing 4 screws.
  8. The main motor housing can be taken off by removing a single screw at the back of the upper assembly. The main motor housing can be taken off by removing a single screw at the back of the upper assembly.
    • The main motor housing can be taken off by removing a single screw at the back of the upper assembly.
  9. There is a capacitor attached to the oscillator by a single screw. Once the screw is removed the capacitor should come off easily.
    • There is a capacitor attached to the oscillator by a single screw. Once the screw is removed the capacitor should come off easily.
    the two wires of capacitors are connected where ?? please guide me.
    mohangmysore - 답글
    The two wires are normally connected to the motors, start winding.
    zakk - 답글
  10. Remove the screw that connects the oscillator to the rocker arm. Push down on the rocker arm after removing the screw and turn it away from the oscillator.
    • Remove the screw that connects the oscillator to the rocker arm.
    • Push down on the rocker arm after removing the screw and turn it away from the oscillator.
  11. The oscillator should now be easy to pull off.
    • The oscillator should now be easy to pull off.
    • Clean the oscillator and remove any jams. If the problem persists the oscillator is damaged and needs to be replaced.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alan Su
회원 가입일: 2012년 10월 03일
537 평판
안내서 6개 작성하였습니다
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 회원
CPSU-REGAN-F12S24G28
4 회원들
안내서 10개 작성하였습니다
I bought a fan and two days later my grandson dropped it and it stopped turning. Its been stuck in one position for about two weeks. Finally I said I know someone on the internet is gonna no what is wrong and how to fix it. Thank you. I fixed my fan in about 10 minutes. The oscillating handle had just come lose from the screw. Everybody thinks I'm a genius. LOL! Super grandma strikes again!
kim - 답글
Where do I locate a gearbox kit for a 30” polar aire fan model lfdj-30pbo. Thanks for what ever help you can give me
Eric Delatte - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 112
전체 시간: 8,277
