주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
GD Midea FT30-3D Power/Speed Switch Replacement
필요한 것
  1. GD Midea FT30-3D Power/Speed Switch Replacement, Bottom Base: 1 단계, 이미지 1/1
    • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
  2. GD Midea FT30-3D Power/Speed Switch Replacement: 2 단계, 이미지 1/2 GD Midea FT30-3D Power/Speed Switch Replacement: 2 단계, 이미지 2/2
    • Locate the gray base support release tabs found on either side pictured in the first image.
    • There are release tabs on each side of the base.
    • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
  3. GD Midea FT30-3D Power/Speed Switch Replacement: 3 단계, 이미지 1/1
    • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
    • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
  4. GD Midea FT30-3D Power/Speed Switch Replacement: 4 단계, 이미지 1/1
    • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
  5. GD Midea FT30-3D Power/Speed Switch Replacement: 5 단계, 이미지 1/1
    • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
    • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
  6. GD Midea FT30-3D Power/Speed Switch Replacement: 6 단계, 이미지 1/1
    • Once all five screws have been removed the base cover should fall right off with out any effort.
    • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
  7. GD Midea FT30-3D Power/Speed Switch Replacement, Power/Speed Switch: 7 단계, 이미지 1/1
    • Remove the two 10 mm Phillips #1 screws found connecting the switch to the case.
    • Notice the AC power cord line (white wire) goes into the switch under the [Off] button
  8. GD Midea FT30-3D Power/Speed Switch Replacement: 8 단계, 이미지 1/1
    • Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the wires. Press into the hole gently to release the grip on the wires.
    • The wires should release with ease if done properly.
    • When reassembling; skip this step.
  9. GD Midea FT30-3D Power/Speed Switch Replacement: 9 단계, 이미지 1/1
    • Take the new switch, and simply push the wiring into the correct holes:
    • AC Power Cord (white wire)
    • Low speed (gray wire)
    • Medium speed (orange wire)
    • High speed (red wire)
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alan Su
회원 가입일: 10/03/12
810 평판
안내서 6개 작성하였습니다
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 회원
CPSU-REGAN-F12S24G28
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 13
전체 시간: 3,539
